Kidoo's avatar
Kidoo
Rear wheel leaking oil - third time
Hi, for the third time, my rear wheel hub are leaking oil. I had new seals installed and 2000 miles later, one started to leak. I went for 100 KM and the newly installed seal leaked again, they replaced it with a different type of seal and it was good for another 2000 miles, it started to leak again.
The other side, which did not leak for 4000 miles started to leak too.
I read on some truck forum that sometimes they have to install an insert for proper fit.
I removed the air vent and it is clean, no obstruction.
Any advice apreicated, I am on the road and I keep a close look on the axle oil level.
