RV won't start
Stormy_Eyes
We are newbies experiencing trouble starting out recently acquired 2005 Itasca Suncruiser gasser with workhorse chassis. I'm new to rv's and have never even worked on my cars. I am waiting for a call back from mobile service, but thought I might ask smart people here while I wait.
Last evening it would not start...no dashboard dummy lights or sound when turned the key. Battery boast switch did not help nor did it jump start. Chassis batter read low with multimeter, so we ran a battery charger overnight. Battery reads well this am. Dash dummy lights came on when key turned to acc. When turned to strart, dash lights flashed on, then a click, then nothing. Now back to no sound, no lights when we turn the key. Might somebody share some thoughts of possible problems or any basics a newbie might try?
Thanks
Windy
10 REPLIES 10
ksg5000
Next time your near a Big Box store drop in a buy an inexpensive bottle of noalox - apply after you clean your terminals and you won't have corrosion issues.
Kevin
gbopp
Stormy Eyes wrote:
Thanks everybody. We cleaned and tightened the battery connections. Then she started right up. Your help got us going and saved a service call. Thanks so much.
It's amazing what a little corrosion (even if you can't see it) will do.
When you get a chance, find the ground connection on the frame. Clean and tighten it, you'll be good to go.
Stormy_Eyes
kdk
A lot of responses while I was typing but here goes anyway. Windy, If you have a multi-meter (if you don,t you should get an inexpensive one and learn how to use it, they are priceless in these type of conditions) put test leads on the chassis battery terminal post not terminal but post. Should read approx. 12.6 volts, then have some one try to start and see if the voltage drops. If it drops significantly then your batteries are bad and should be replaced, but if it stays at above 12 volts then put the test leads on terminal on the end of the battery wire and test again by trying to start. If the the voltage then drops significantly clean them battery terminals and the inside of terminal lead of corrosion. Also then clean the ground wires the the frame. Hope this helps. Please post your results and then more trouble shooting can be given if needed.
Blessings; Keith
06 Holiday Rambler Ambassador
2016 Ford Explorer twin turbo
rgatijnet1
Workhorse at one time had an issue with the ground cable connection to the chassis. If all of the battery terminals are clean and if the problem still exists, check where the ground cable connects to the chassis.
gbopp
Are your battery terminals clean? When mine get a little corrosion it causes starting problems.
You said you charged and checked the battery and it's good?
Pull the cables off and clean the terminals, even if they look okay.
Always start with the simple things.
BB_TX
Could very well be as simple as corrosion on the battery posts or side terminals depending on battery type. Have had that happen before on different cars/trucks. Easy to clean if you have tools to remove the battery cable clamps and something to brush the contact points with.
Mandalay_Parr
Sounds like bad batteries.
Would change them first...all of them.
Then verify charger working properly.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
amandasgramma
Is it in PARK? Don't get mad or laugh, I actually had my Step-father come over because I couldn't start my RV. Had same issues, lights came on, but nothing. I didn't have it in PARK. My face is still red.
My mind is a garden. My thoughts are the seeds. My harvest will be either flower or weeds
Dee and Bob
plus 2 spoiled cats
On the road FULL-TIME.......see ya there, my friend
Ranger_Smith
Sounds like either bad batteries for the chassis or a bad cable connection.
Where we are now
Amateur Radio Operator WW1SS . . . Flex 6500 PGXL and TGXL
Steve and Joy
2014 Itasca Suncruiser 38Q . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
