โJul-28-2013 01:45 PM
โJul-29-2013 01:20 PM
โJul-29-2013 12:56 PM
โJul-29-2013 12:42 PM
โJul-29-2013 11:16 AM
โJul-29-2013 10:14 AM
ferndaleflyer wrote:No you are not wrong, however tow/haul mode means different things to different transmissions. In your specific case, it locks out overdrive, as your truck is geared to purr along at a super low RPM, to get better mileage. An RV is not geared that low to begin with, so tow/haul mode doesn't need to shift out of overdrive, however it does change the shift points.
I have 2 Fords and if in OD and hit the TH button going say 60mph it will shift out of over drive and the rpm will increase. I would assume that more RPM means less fuel mileage.....could be the reason it gets 17mpg without the TH engaged and 15mpg when it is.....Am I wrong or is there some other reason the mpg changed. This was on a 350 mile each way trip towing nothing.
โJul-29-2013 07:11 AM
โJul-29-2013 02:57 AM
KD4UPL wrote:
IF it hurts MPG it would be so small as to be nearly undetectable.
At cruising speed the torque converter would be locked whether in T/H or not. The RPMs would be the same. The shift points wouldn't matter because it's not shifting.
When stopping, starting, accelerating, etc. T/H off may give the mentioned nearly undetectable increase but that's not the point. T/H mode is the proper mode according to the designer of the vehicle for the situation. It provides better acceleration/deceleration and less mechanical wear on the vehicle. I wouldn't sacrifice vehicle control and longevity for .1 MPG.
โJul-28-2013 07:03 PM
โJul-28-2013 06:28 PM
wny_pat wrote:
Using A Transmission with Tow/Haul Ignore the "Ignoring the Barking Dogs" article and skip right down to the towhaul article.
โJul-28-2013 05:18 PM
โJul-28-2013 05:10 PM
โJul-28-2013 04:14 PM
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
โJul-28-2013 02:39 PM
โJul-28-2013 02:38 PM
Bob & Betsy - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
