Joeycockerspani's avatar
Mar 07, 2015
Stains under/on clear plastic "bra" thing
Hi y'all,
The manufacturer installed on of those clear, plastic protective "bras," for a lack of a better term, on the front end of my motor home. Now, several years into it, as you can see, I have all sorts of brown stains, either under the coating, or the coating itself. Has anyone had this before? If so, what to do about it? Does that plastic protection come off? If so, how? Will the stains come off with the plastic?
Thanks,
Hank
  • Yep, turns out a royal PIA. Turns out the best tool is a plastic spatula! Plastic won't scratch the paint and has rounded edges that won't tear the coating as you work it underneath, breaking it loose.
    Thanks for the help!
  • I'm convinced this is not a good product for other than the dry western states. It seems that folks with problems are from the Midwest/South.
    Ours was on for 11 years and still was perfect when we sold the motorhome. We traveled in the West.
  • WE removed ours but would NEVER do it again. We still had to pay someone to remove the last 18" strip at the bottom and have the front repainted. If you decide to remove it yourself: Get a heat gun and some plastic razor blades with holder or we used some plastic paint scrapers. Do not use heat gun on high setting! Use the heat gun to soften the plastic outer coat. Then scrape (carefully so you don't gouge the paint underneath) the outer plastic coat off. Once you have that done (2-3 days all day and sore fingers, hands and arms!) then get Goo Gone from Home Depot, Dollar General etc. You will need 4-5 bottles. Spray the Goo Gone on the adhesive and rub, rub, rub until adhesive is off. Unfortunately no easy way to do it. We decided that we would have paid the $1100 quoted to have someone else do the job!! I would never have that stuff put on another vehicle we own!!
  • We had the same problem - mold growing under the shield. It looked awful. It's a bear to remove yourself and there is a good chance the paint will be ruined in spots. We had Dazzling Detail remove it. I think the cost was north of $1000. I will never have another 3M shield put on.
  • katysdad wrote:
    Diamond Shield tech used a wallpaper steamer to heat and soften the film then cleaned up behind it with zylene. The steam will not over heat the film but soften the glue behind it without making the film too weak to pull off in larger pieces.
    Previous post Diamond shield removal
    X2
    The Rep. that replaced mine used a steam gun, heating it and pulling it horizontally to the side vs. 90 degrees from the surface. He removed it in big sheets. When pulling it stretches and lifts from the surface. Seems like it took him between 1-2 hours, but that was 5 years ago and I don't recall the exact time.
  • Diamond Shield tech used a wallpaper steamer to heat and soften the film then cleaned up behind it with zylene. The steam will not over heat the film but soften the glue behind it without making the film too weak to pull off in larger pieces.
  • It is the beginning of the end for the film. It will only get worse over time.
    Removal is a lot of work. Many procedures have been described on this forum and others. I removed mine this past fall while at Myrtle Beach, working on it when the sun was shining on the front of the coach. I used plastic razor blades to raise and edge then slowly pulled it off in sheets. The adhesive is a bear. I soaked it with mineral spirits, scraped it off, repeat. Once I got all I could get off with the mineral spirits, I wiped it with lacquer thinner to remove the rest. Waxed the paint and it was pristine.
    I spend several hours every day for about 5 days to get the stuff off.
  • Removal and replacement quotes I've heard is around $1000, if the paint isn't damaged on removal. Ours has the mold also and it's getting worse, looks like the front end is bug splattered, except its clean.
  • It is a 3M protective film, factory installed and what you are seeing is dirt/mold/mildew between it and the factory paint. It does come off, but is a BEAR to remove. My good friend had it on his, he spent several hours a day with plastic razor blades slowly peeling it off and it took him over a week. We tried goof off, and several other chemicals to no avail. I do know that the warmer it is, the easier it is to remove. He parked facing the sun and worked on it in the heat of the day. You could try a hair dryer, but I wouldn't recommend anything hotter like a heat gun.
    Good Luck
