JCMack's avatar
JCMack
sterring stabilizer
I am studying putting a front steering stabilizing system on my 05 W24 chassis Newmare Mountain Aire (37 feet). I would like to receive input from other RVers both pros and cons who have installed this system. Thanks to all.
  • wa8yxm's avatar
    wa8yxm
    Stablizers in general have one major problem.. TWO brands (Far as I know) Address this problem.
    The problem: They all try to center your wheel, What happens if center, is no longer center? The road could be "High domed" which tends to push you to the right so you need to "Center" a bit more to the left, or there could be a medium cross wind (Strong cross wind you park) which tends to push you down-wind so you need to re-center up-wind.
    BLUE OX True Center has a button you push, inside the motor home, it re-centers. (Short comment follows)
    I understand the Saf-T-Steer has an optional remote re-center device (Adjustment) as well.. at least I think that is the brand.
    Just how much difference does one of these make.
    Blue Ox says not to press button while in motion but,, Of course,, You do because in truth that is the only way to get it right (I do find i have to slightly over correct so it takes a few tries)
    Well, you have seen those disabled pilot TV shows or movies where some novice has to land the plane.. When he turns off the auto pilot he dang near looses control.... BELIEVE IT, that's how much difference it made when I pushed that button (Thankfully I was limited speed).
    Short story 2: One of the problems with the Blue Ox system was the soleniod burning out when folks "Sat" on the button for like 10 minutes at a time, SO a multi-trained engineer suggested putting a timer in the line.
    My original failed, they replaced, the new one came....... with said timer in the box.... (Yes, I was the "Engineer" above).
  • the bear II wrote:
    Used them in the past and have been satisfied. Need one now but haven't taken the time to add one.
    They really help on bumpy roads, crossing railroad tracks, grooved pavement...dampens the effect on the steering. Many have claimed they helped when a front tire blows out...I've never had that happens so can't speak to it.
    I've never understood this---------and I had a front tire blow out this summer at 67 mph. There was no jerk to the steering wheel due to the steering gear (worm) and power steering. Although the MH moved to the left a bit, it was not a problem correcting the direction and moving to the shoulder.
  • Harvard wrote:
    A "natural" method of increasing stabilization is to increase the +caster to top end of spec. JMO
    X2
    Skip the band aid until you've done this.
  • Used them in the past and have been satisfied. Need one now but haven't taken the time to add one.
  • A "natural" method of increasing stabilization is to increase the +caster to top end of spec. JMO
