- Mr_Mark1Explorer
AikenRacer wrote:
Sorry for the ignorance, are we talking about tire pressure or air bag pressure?
AR, this is funny. You started the thread, why don't you tell us exactly what you want to know.
Your post is titled 'tax axle pressure' which would make me think you are talking about the bag pressure on the tag axle. If you were referring to the tires, you would have said tire pressure on the tag axle.
MM. - AikenRacerExplorerSorry for the ignorance, are we talking about tire pressure or air bag pressure?
- barlow46ExplorerAdjusting it by the gauge in the engine compartment will work for an estimate but you really need to go to the scales and do your adjusting there based on your weights. Remember added pressure on the tag increases the weight on the front axle so check that weight each time you cross the scales. After you get it adjusted where you want, then take a look at the gauge and use it for a reference based on your load.
- Passin_ThruExplorerUsually hooked to the airbags on the drive axle and run the same P, having a rod attached to the axle or spring hanger which adjusts load height automatically.
- Mr_Mark1ExplorerAikenRacer, there should be a pressure gauge in the engine compartment to tell you how many pounds are on the tag axle (on our Roadmaster Chassis). There should be a notation in your owner's manual for procedures to change that pressure.
On our 2008 Monaco Dynasty, it's in the engine compartment on the driver's side which is easy to see.
MM. - trop-a-calExplorerThe old fashion way, an air gauge when tires are cold. Inflate same as rear duals. You may be able to get an after market monitor for them, as the factory set up probably was no tag and RV company added tag.
About Motorhome Group
38,707 PostsLatest Activity: Feb 17, 2025
