- garry1pExplorer
- tderonneExplorerThat is a tough one (looking at Google images). Must be from something, but what....
Old thread with a little info
Seller SAYS it's a Travel Supreme brakelight - wny_pat1Explorerhttps://groups.google.com/forum/#!forum/travelsupreme_5thwheel_rvers
and this appears to be the tip page of one of the TS owners groups:
http://www.travelingsupremes.com/TSTips.htm. There are some supply sources listed there. - smlrangerExplorerAnother tip from someone on IRV2.com with an 04 TS with same question....call Terminal Supply in Troy, MI.
- smlrangerExplorerI have found that if you can find numbers/markings on the light, Google them and you may just get lucky.
Another option is to check with Entegra Coach. They seem to be using some of the same body panels (especially the rear) previously used by Travel Supreme. They may just have it or can give you a source.
About Motorhome Group
38,709 PostsLatest Activity: Mar 09, 2025
