jolooote
Aug 30, 2016Explorer
Thor Vegas/Axis widespread E-350 Transmission Cable problem
Googled it and found that there is a bad problem with the Transmission cable laying against the rear end of the HOT exhaust manifold and burning thru. It will not allow the transmission to be shifted into Drive when damaged. Look under the MoHO inside the frame member on the drivers side. If barely touching or close total damage may not yet have occured. Strap it away from the heat. Call Ford. Do NOT let them tell you its a Thor problem due to chassis lenghthening. That has nothing to do with this area. :E
