- lanerdExplorer II
rgatijnet1 wrote:
Some braking systems, like the Blue Ox Patriot system, will allow you to push a button on the dash of the MH to apply the toad brakes.
The OP's US Gear Unified brake system controller (on the dash of the rv or wherever the driver wanted to install it) does indeed has a lever on the front that allows you to manually and incrementally activate the toad's brakes without using the mh's brakes.
For the record, this supplemental brake system is one of the highest rated systems available today. :C
Ron - rgatijnet1Explorer IIISome braking systems, like the Blue Ox Patriot system, will allow you to push a button on the dash of the MH to apply the toad brakes.
- ctpresExplorerFWIT - Lynch pins are used everywhere on tractors and somewhere I learned the correct way to install lynch pins is with the flat side against connecting parts ie facing away from the end of the pin.
- lanerdExplorer IIThe toad hit the motorhome because, contrary to the OP's statement, the toad's brakes were not applied. It's obvious that if the toad's brakes were applied, the toad would have been slowed to the point that it would have been at max length of the remaining tow bar arm. My only guess is that either the driver let off the brakes either during the slow down period or after stopping....both releasing the toad's brakes allowing it to coast forward into the motor home. I guess another possibility would be that he had the toad's supplemental brake system turned to low so that the toad's brakes weren't activated.
With this adjustable system (US Gear Unified Brake System), you must find a happy medium on the adjustable control so that the toad's brakes won't be set so high that you will be dragging the brakes and conversely, not so low that the brakes will only be activated during a panic stop.......which maybe the OP's DH had done.
Ron - Tal_ILExplorerMy tow bar uses this style, which is very secure
- johnhicksExplorerI have two clevis pins under the toad and there's no room for a locking clevis pin or padlock. My takeaway is that I should use standard cotter pins of the spread the legs and wrap around type. Right?
My safety cables give only a couple of inches slack if one of those pins vanishes.
Why did the toad hit the MH? Shouldn't it be simultaneously braking? - J-RoosterExplorer
wa8yxm wrote:
Thanks for the explanation! I wasn't aware the two different parts were compatible. JohnJ-Rooster wrote:
I don't understand them using two different tow bar systems Blue Ox and Roadmaster together? And the cotter pin he shows? I don't use them (I've never trusted them) I use padlocks in the place of those pins.
Many people use either roadmaster tow bars with Blue ox base plates or the other way around. both companies make "Adapters" for selected base plates and/or are compatible up front.
The "Cotter Pin" is actually misnamed, that is called a "hair Pin" not a cotter pin... though they serve much the same function, Cotter pins would NOT have come out since you "Spread the legs" but cotter pins are not designed to be inserted and removed over and over again hair pins are.
I use spring clip pins there they have a curcular spring that is bi-stable (means it will rest in either of two position) we used these exclusively on the farm to hold the draw bar, plough, cultivator, mower and other 3-point hitch devices to the tractor and I've never had a problem with them.. I do not think they can come loose.
I used to use hair pins at the other end of the Tow bar however (Motor home end) till one came out exactly as described above and cost me around 2,000 in repairs, I now use either padlocks or pins you need to use TOOLS to remove. I do not trust the hair pins at all.
Page 2:
Padlocks v/s a "Quick Release" on the car end.
I have read of many a RV fire, even seen one (though that was a TT) and the faster I can disconnect the other vehicle (Towed in my case, Towing in the case of the TT) the less damage to the other vehicle.
In the case of the TT though it was the tow vehicle that went up. Some smoke damage to the trailer but nothing a good bath would not cure.
(Fire was already on scene when I drove past so I kept on trucking, he also had a friend with a 2nd tow vehicle so they could get him off the freeway w/o my help, I'm not rated to tow that much anyway)
I've also had a Tow vehicle that looked like it was on fire.. But was not. Turned out to be something easy to fix.. AAA tow and a new piece of transmission line and some fluid. (it was hot oil on a hot exhaust, lots and lots of smoke, and I mean LOTS of smoke, no fire though)
But I'm a firm believer in quick release in the event I need to quick release.
That said.. A second danger.. Some folks theorized the hair pin had been pulled as a prank when I lost my towed (Oh, the safety cables,, I always wondered "Will they hold" I now know.. they did) but due to some things I did not include above that would have been impossible, I thik I know how the pin got pulled, but of course can not prove anything... but it was an accident, not intentional. (I'd inspected the hitch a short time earlier no chance for anyone to pull the pin unless they were running very very fast) - usersmanualExplorertheoldwizard? I have no idea what your trying to say? none of lock pins pictured are worth a hoot in my opinion Milehighs picture is the one and only lock pin I use and only one I would use
- theoldwizard1Explorer IIThe heavy (1/2" diameter) pin is the "clevis pin". (CORRECTION ! They are typically called "bent handle hitch pins.) (Hitch pins are usually longer, larger diameter and have a large handle.) The thing they are calling a "cotter pin" is actually a "clevis/hitch pin clip" or generically, a "keeper".
There are 2 different styles of clevis pins. One that has a hole drilled through it for the pin clip and one that has a groove cut all the way around the pin for the clip to ride in.
Clevis pins and clevis pin clips have been used for dozens and dozens of years with very few incidents. A clevis pin with a hole for the clip is likely a bit more "robust".
The smallest diameter lynch pin I can find is 3/16" diameter which would require a fairly large hole in a 1/2" diameter clevis pin. More appropriate for a 3/4" hitch pin.
There are several different styles of clevis pin clips. Most of the others I have seen have positive locking but are formed out of thinner wire.
Circle cotter pin
Saftey Pin
- John_WayneExplorer III attended a seminar that recommended you adjust the brake a way cable so it's 3 to 4 Inches shorter then the safety cables. So in the event that the toad comes unattached the toad brakes come on before the safety cables become tight and the toad will be braking as you pull to the side of the road. It may have worked in this case as the toad pulled to the side.
About Motorhome Group
38,764 PostsLatest Activity: Dec 23, 2025
