Pangaea_Ron
Aug 30, 2016Explorer
Toyo M145 valve stem core issues
I recently purchased (6) Toyo M154 245/75 R22.5 tires for my MH from Les Schwab Tires.
I checked the tire pressures when I got home. The pressures were correct (105psi front and 95 psi rears) The valve stem cores did not seat after I removed my tire pressure gauge from the front tires. I needed to use the valve stem caps to prevent the tires from deflating.
I returned to Les Schwab Tires to get replacement cores, which seemed to correct the issue. I also took in my tire gauge and air-compressor filler with gauge for them to calibrate and verify that they were not a part of the issue.
I experienced the same issue again and returned to Les Schwab Tires and they again replaced the valve stem cores with no issues.
I now have low pressure in the front tires (85psi) and the valve stem cores did not reseat after pressuring up the tires to 105 psi. I'm relying on the valve stem caps to maintain pressure.
Any thoughts about what is happening?
