kemer
Oct 25, 2015Explorer
Tranny/OD/Tow Haul
Driving a 2014 Winnebago Sightseer and pulling a Pontiac Vibe(on dolly)....I use the tow/haul mode on the transmission. If I set the cruise at like 60mph, when I hit a uphill, the tranny shifts and rpms will run way up to around 5,000...normal running at 60mph produces rpms of 2-3k....is running at 5k, acceptable? Don't like doing it for a long stretch. I have been backing off the cruise and just driving normal, even tho' speed drops down as I climb. Basically the same happens when going downhill. Engine will drop gears to slow down and rpms jump. Responses welcomed.
THANKS
THANKS
