โOct-12-2017 08:19 AM
โOct-12-2017 04:29 PM
โOct-12-2017 03:56 PM
โOct-12-2017 02:03 PM
Chum lee wrote:
It's best to use an OEM coolant temp sensor. Pull off the positive chassis battery cable for +-5 minutes then reinstall it. That should clear the fault code. If it comes back, you probably still have a bad/wrong sensor or a wiring issue.
You probably have a V-8 if you have a 1997. If you told the parts guy you have a V-10 instead of a V-8 that might explain it.
Chum lee
โOct-12-2017 12:37 PM
โOct-12-2017 10:31 AM
โOct-12-2017 10:04 AM
โOct-12-2017 09:52 AM
โOct-12-2017 09:47 AM
