vw's avatar
vw
voyager camera monitor
we have a 2006 Winnebago journey .I need to remove the monitor unit out of the dash.
question is how do I start and what I have to remove
thanks for the help
rudi
rhs@wavecable.com
  • I don't have a Journey but do have the Voyager. Just start removing trim around the dash. Take your time and the project itself will tell you what needs to be removed. Use a zip loc to hold the loose items.
  • On my 2006 Voyage, the dash lifts up, there are four knobs that unscrew and then just disconnect the wiring. The monitor slips right out the back side of the dash.
  • With my Voyager monitor there is a trim piece that is removed around the edge. It is about a 1" frame around the entire monitor and it just snaps on. Once it is removed you will see the "push" place that you can push on to release the monitor and allow it to be pulled out, leaving the support frame in place. This will allow you to get to all of the wiring on the back of the monitor. If you want to remove the support frame, you can now get at all of the screws.
