ken_burke's avatar
ken_burke
Directv SD Signal
Traveling cross country, we found out that not all zip codes support Direct TV SD (standard definition). Sometimes we set up the 18 inch satellite at a campground, and can not get local channels (including NBC, CBS, FOX). We have to call direct TV tech support and beg them to change our address to get SD programming. Give them your zip code and they can tell you if that area get SD signal. (Assuming you get a Direct TV tech that knows what you are talking about.)
How else can you get NBC, etc, using a SD satellite?
thanks ken
