nbargolf
Oct 11, 2013Explorer
Rand 7710
have one question about the rand 7710. Can you download your own custom routes to it. all the Garmin's do, this is a feature I use all the time I prefer doing my own routeing.
nbargolf wrote:
Thanks for the replies. Seems like the answer is no to doing your own routes. The Garmin RV760LMT will do this and has the RV features. Cost more of course but looks like the way to go for me anyway.
emiddleb wrote:
To the OP: I've had a 7710 since it came out. Use it regularly.
While (as others have said) you can download POIs from various sources, I've not found a way to download an actual trip to the device. So if you are looking to do something like create a trip in MSoft S&T and then download it to the 7710, no, I'm not aware of any way to do it. S&T does allow you to export a GPX file but the 7710 doesn't seem to use that format.
Medico wrote:
I can download my own POIs on my Rand 7725. Check here for customized POIs. You can't use them all, but the CSV files can be used by Rand.
