Thedawg28 wrote:
Ok I guess I'm confused here. On outside of camper we have 2 hookups, a satellite and park cable. I'm hooked into our satellite and in the inside on mainroom TV it has 2 different hookup for satellite or park cable but the other room tv jacks don't. In the bunk room we can't get any satellite signal with our receiver. Any advice?
Normal.. Satellite has to be connected DIRECTLY from the receiver to the antanna, you can not have any "Devices" save for some very special devices sold specifically for Sat use, and those are specific to the service you choose, so the RV maker can NOT install them.
If you are using a DISH antenna with DUAL output. Put in a 2nd RG-6 Coax for the 2nd TV position and hook up both cables.
OR you can get the proper digital switch gear (From your sat provider) and then "Split" (really switch) it at the main equ8ipment bay and run a line from there. Please run new RG-6 for the Sat Receiver, do not use the 59 POrovided.
