- tourusaExplorerI’m thinking it was dirt started working again so I’m not touching it
- SoonDockinExplorer IIIf you pull the surround trim from the fan, you can likely find the wires that feed it. Look for where the wires are tied and make sure they are connected, most crimp connectors or wire nuts can be probed with a meter to check voltage.
- MFLNomad II
slider45 wrote:
MFL wrote:
2oldman wrote:
I don't have a clue, but my fan hasn't been that clean in years!
Well, your not much help...but I'll help you! You need to change your maid service!
Agree with ron above.
Jerry
You sir are surely getting a quality service!
Absolutely...I am fortunate to live and camp, with a Domestic Engineer!
To the OP...did you get your fan going? - slider45Nomad
Jerry
You sir are surely getting a quality service! - tourusaExplorerThe plunger switch can I get to it from underneath
- wa8yxmExplorer IIIThere are a few parts that are suspect
First is there 12 volts to the fan assembly (Use a test light not a volt meter please) (Bright is good, Dim is not)
The 4 position switch (OFF LOW MED HIGH)
The Thermostat
The Lid Switch
You can bypass the lid switch and the T-Stat to test.
Not sure how the 4-pos is wired. so not sure how to bypass. - bob_nestorExplorer III
ronharmless wrote:
If the fan only can come on when the vent cover is open, then there is a switch in the vent cover. Use a volt meter and check the vent cover switch. You can also jump/bypass the switch to see if it is malfunctioning. You can jump the 0 - 3 switch also to see if it is malfunctioning.
The switch is just a plunger and you can try tugging on the plunger to see if the fan comes on. When the cover closes it pushes the plunger down which disables the power to the fan. The plunger switch tends to get corroded or stuck with gunk, especially when camped near the seashore. If it is the plunger, a little WD-40 will clean it up and solve the problems. - MFLNomad II
Jerry - ronharmlessExplorerIf the fan only can come on when the vent cover is open, then there is a switch in the vent cover. Use a volt meter and check the vent cover switch. You can also jump/bypass the switch to see if it is malfunctioning. You can jump the 0 - 3 switch also to see if it is malfunctioning.
- 2oldmanExplorer III don't have a clue, but my fan hasn't been that clean in years!
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: Feb 16, 2025
