GM integrated brake control
Bob_Vaughn
I was at the rv repair shop this morning for the second time about my brake controller not working....It was determined that the integrated control was not functioning and was sending a constant 3.6 volts to the brakes. As I was leaving there was another guy there with a truck like mine that he only had 2 weeks and his brake control did not work either. Is this an inherent problem with GM integrated controllers?
21 REPLIES 21
minnow
If you have a IBC, can you disable it and install a conventional controller ? If that is the case, it would seem that if the trailer brakes work well with the aftermarket controller, then it would indicate a problem with the IBC. If the aftermarket controller also had inadequate braking then it would lean towards bad connections/wiring ????
Lynnmor
justafordguy wrote:
CarnationSailor wrote:
APT wrote:
Carnation, can you adjusted the trailer brakes?
The brakes are self-adjusting so I shouldn't have to adjust them. However, I could look into that next Spring.
I'm not unhappy with the current braking. It's just I'm not sure I'm getting the braking power that I should.
I thought the same thing about my new Gateway. It has self adjusting brakes and even with the controller set to 10 the brakes are marginal. I checked the adjustment last weekend and they were way to loose. I'll be towing it in a few weeks and hopefully it will be better.
The brake manufacturers have a runout tolerance that is too great for self adjusters to work properly. You might get lucky and have good drums or maybe not. Adjusting manually is still the best.
BarneyS
Bob Vaughn wrote:
How would you know if your brakes were self adjusting???
The brake drum will have a cable that runs to the shoes. See this post by member Jbarca for pictures of what they look like.
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
Bob_Vaughn
justafordguy
2015 Heartland Gateway 3650BH
2017 F350 CCLB KR FX4
2005 F250 CC FX4
77 Bronco, 302,C4,PS,PB,A/C,33" KM2s,D44/Lock-Right,9"/Grizzly locker
trail-explorer
mkirsch wrote:
... Trailer manufacturers are notoriously cheap, and use substandard wire for the brake connections. They tend to use 12ga or 14ga wire when it should be 10ga or possibly even 8ga.
Voltage drop in 12VDC systems is bad.
ANd they often times use crappy methods of crimping the axle wires to the trailer wires. I've even seen WIRE NUTS used!!!
Bob
Bob_Vaughn
bailer6334 wrote:
Bob,
I was on another forum and they were discussing the same problem you have. Sorry can not remember the forum, but the cause was a bad connection between the truck wiring and at least one of the pins in the 7 pin plug. Not enough voltage ( I think 12-15 volts is normal)was going through the pin to activate the brake controller properly. GM techs did not find the problem, a trailer hitch tech discovered it.
Hope this helps isolate the problem.
I have a 7 way plug tester and the brake light just flickers when I apply the trailer brakes, a trip to an rv place cost me 295 bucks and was told everything was rewired from the ITC back to the plug. Still did not work. A trip back with two techs working on it telling me the controller was not sending voltage back to the trailer pin. Got a 50% discount and paid 115 bucks. Took it to the dealership to have the ITC replaced. They called and said nothing was wrong and they hooked it to a TT and the brakes worked......BUT they did not tow it just listened to hear the magnets. I took it hooked it to my 5th wheel and with my wifes help I could just barely hear the magnets and there was very little resistance when doing a pull test. I am at a wits end as to what my problem is.....It is keeping me awake at night.
mkirsch
Nomad II
Nomad II
You probably aren't. Trailer manufacturers are notoriously cheap, and use substandard wire for the brake connections. They tend to use 12ga or 14ga wire when it should be 10ga or possibly even 8ga.
bailer6334
Bob,
2017 Grand Design Imagine 2150RB
2016 Chevy 2500HD LT 6.6L DMAX 4WD
Equalizer 4 Point WDH
jareddustin
no issues on my 2009 but if go over to the duramax fourms you can read more in detail about other people having issues and what they needed to do, tons of info over there
Elbert
2014 2500 HD with no issues with the IBC. I did have some problems with the trailer connection and wiring which I solved on the trailer side. Just got back from a 3200+ mile trip.
Bob_Vaughn
My 2013 GMC has never stopped my 5th wheel like my 2000 Chevy did with an aftermarket control. Mine has never been right from day one, I just thought it was the nature of the beast.....NO VOLTAGE goes to the brake connection on my plug.....
allen8106
I have a 2013 GMC. My controller seems to work not great but ok. I`m thinking maybe it could be a bad connection or possibly undersized wire on the camper.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
Michelle_S
OK, here's the story on GMs. The installed Brake controller send a digital signal down the line (approx 3 to 4 volts) looking for the correct resistance. Once it see the correct resistance it will give the "Trailer Connected" message and will now supply the proper voltage and current to the brakes. What happens these "So called Techs" put a voltmeter on the brake control line and read that digital signal and tell you there is a problem with the controller which is untrue. I have over 86K on my 3500 and 90 to 95% of that mileage is towing heavy without any trailer brake problems.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
