belfert's avatar
belfert
Goodyear Marathon tires are not good tires
I bought Maxxis trailer tires in 2010 for my trailer. I even went with one load range higher to be safe. In 2012 I had two sidewall punctures in 150 miles and my only option for two new tires were Goodyear Marathons.
One of those Goodyear Marathon tires failed badly yesterday. The tread was worn all funny and the tire had a large hole in it with the steel belts exposed. I have TPMS on the trailer tires so they never ran low on pressure and I stopped right away when the TPMS went off. The tire only has like 12,000 miles on it so the tread shouldn't be so worn. The three remaining Maxxis tires still look practically like new with twice the miles on them. I don't see anything wrong like a bent spindle, bad suspension, or hot hub that would cause the tire to wear funny.
I may have hit something, but still, the tire shouldn't look like the tread is nearly gone with the relatively low miles. I'll see if my road hazard will cover a new tires. If not, I will be getting another Maxxis trailer tire.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,150 PostsLatest Activity: Jul 21, 2025
