Horseman120247
Oct 02, 2013Explorer
Goodyear Marathon Tires
I know this has been beat before, but I purchased a 2011 40 foot Jayco Pinnacle. It came with 235-80-16 load range E Goodtear Marathon tires (dated 2010).
I recently took a cross county trip from Syracuse, NY to Vancouver Island BC. I blew the first tire in Minnesota, second tire in Victoria, BC, and then on return trip blew the third and fourth tire both in Des Moines Iowa.
These tires started the trip with approximately 6000 miles and the last tire blew with approximately 13,000 miles.
When these tires blow the whole tread and center section atre coming off and the only thing left on the rim is the two side wall discs.
The first failure in Minnesota damaged the wheel fender flare and dented the lower aluminum skirting on the passenger side slide-out.
I am pursuing this through Goodyear and would appreciate knowing of tire failures of the same size and approximate age and mileage.
