โAug-25-2020 08:33 AM
โSep-14-2020 10:54 AM
BarneyS wrote:
I would aim for getting the brackets at the right level so the bars rest evenly across the surface. Than I would tilt the hitch head rearward until I got the weight transfer that I wanted.
This all assumes that you trailers A frame can take the stress of the additional pressure the WD bars will put on it via the brackets. You have very strong, square, non tapered WD bars that are not too flexible. It is not unheard of for A frames to bend or break from excess WD pressure, especially when going through a dip like you would find at a gas station or other driveway or even some RR crossings. If your frame is a 6 inch frame or larger it should be ok.
Barney
โAug-28-2020 01:07 PM
MHay wrote:
Snip...
I'm using a Curt TruTrack hitch rated at 15,000 GTW and 1,500 TW. Currently I have the brackets on the trailer as high as they'll go. I have not tried tilting the hitch head yet, which I believe would apply more tension. As it is now, the trunion bars seem to be exerting lots of force on the angle brackets, to the point where they are wearing through the black paint on the front of the brackets and starting to mar them. Should I try tilting the hitch head back in an attempt to get more weight off the rear axle, or does it seem like I'm fairly maxed out already? Here's a link to the instructions: Curt TruTrack Hitch.
We're headed on a trip tomorrow, so I'll try to get a picture of the current setup once I'm hooked up.
โAug-28-2020 12:28 PM
โAug-28-2020 11:01 AM
โAug-28-2020 05:57 AM
โAug-27-2020 08:20 PM
โAug-25-2020 02:29 PM
โAug-25-2020 01:52 PM
valhalla360 wrote:
What the GVWR on your truck? I did a quick check online and it looks like 7300lb but you are at 7580lb already but you might have a different model from what I found.
โAug-25-2020 12:34 PM
RobWNY wrote:
I'm confused how you lost 20 pounds completely using WDH bars (14,140 compared to 14,160 for the other two weight rating passes).
โAug-25-2020 11:57 AM
MHay wrote:
As I think about the numbers some more, things don't add up to me. When using the weights in my original post to calculate tongue weight, I get 940 lbs. However, looking at the drive axle weight on Pass 2 (connected to trailer, no WDH bars), the change in axle weight is 1,400 lbs. from the unloaded weight (Pass 3). If tongue weight is 940, how is the axle weight increasing by 1,400 lbs. when hitched to the trailer without WDH bars? I might need a physics refresher to set me straight.
โAug-25-2020 11:50 AM
JIMNLIN wrote:I also checked some weights I got at my local garbage transfer station and they were also in 20 lb multiples.
Thus a difference of 20 lbs on separate weights can be expected.
OP...maybe I read it wrong about being over a RAWR I would take some weight off the trucks rear axle. A RAWR is the lessor of a wheel/tire/rear spring pack or the axle itself. Most trucks today weak link can be the OEM wheels or rear spring pack.
โAug-25-2020 11:26 AM
โAug-25-2020 11:09 AM
โAug-25-2020 11:07 AM
wing_zealot wrote:
Your WDH is moving 400 lbs of weight out of a total of 940 lbs. That's 42% which is pretty **** good. Your tongue weight is also 12.7% which is good also. The only thing you can do is try to shift 150 lbs of weight inside the trailer so it's off the tongue and onto the trailer axle. If you can't do that, then It's just to much trailer for that vehicle.
