walker2413
May 14, 2013Explorer
I can not get my fresh water pumping again
On Sunday I tried to de-winterize my trailer. I first used the city water connection to flush out all of the anti-freeze. I switched the water heater bypass to normal and filled it. I disconnected the city water, then I put some water into the fresh water tank. I then tried to get the faucets to turn on. There is lots of gurgling of air and almost no water. For some reason I put more water in the holding tank. The tank started to overflow, and the water started to pump. Then it stopped and I have not been able to get the water going again. I had similar problems last year but I left the pump on for several minutes and everything worked well. This time I have left the pump on for several hours and I still only managed to get a trickle out of the faucets. Does any one have any ideas?
