superrayzor's avatar
superrayzor
Invisibrake not charging tow vehicle.
Dealer installed an Invisibrake. I am towing a 2007 Honda Odyssey following the procedure outlined on this forum. I make sure EVERYTHING is turned off before I tow it.
I repeat the procedure and let the engine run about every 2-3 hours. At the end of the day I have a little trouble getting the engine to turn over. So far haven't had it die completely, but it's getting close.
I have the 2016 F53 chassis. Is there something special I need to be doing to get the tow vehicle battery to charge with the Invisibrake? There is a red wire running to the battery on the Odyssey which I assume is meant to charge it.
