OFDPOS's avatar
OFDPOS
Never Assume !
Last fall winterized the MH , etc , checked all fluids etc... checked all the tires , set them at 70 rear and 65 front.
Got it out yesterday morning did the usual visual check over filled up the fresh water tank added the bleach let it set over night ,turned on the water pump and ran it through the sinks and bathroom shower/toilet . let the bleach/water set in the grey and black tanks for awhile.
Took it out for a blow the cobwebbs off spin.
Yep you guessed it I didn't check the tire pressures.
When I got back home I checked the tire pressures found inside rear dual at 22 lbs.
Looked for any screws/nails in the tire but didn't see any.
I'll have to take to the tire shop tomorrow and have it checked.
So make that one of your first things to check before you even move it ...
