mileshuff's avatar
mileshuff
Possible damage to water heater if bypassed while on?
Brand new 5'er. Turned electric and gas on to heat up water. Couple hours later found no hot water. Checked breakers, propane etc. and all were fine. Figured heater must be bypassed. Checked and sure enough, dealer had left valves in bypass mode. Fixed that issue and heater tank filled. However, pressure relief valve was wide open pouring water out as fast as it came in. Water was cold at this point and no actual pressure existed. Replaced pressure valve and water now heats as it should.
Question is whether any damage could have occurred to heating element or anything else? Could a tank of hot air have caused the relief valve to fail and stick wide open?
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,105 PostsLatest Activity: Jan 25, 2025
