mike-uswest's avatar
mike-uswest
Apr 20, 2020
Prodigy Brake Control ?
I have a Prodigy brake control on my truck and having a problem with it. I tried calling the company to ask some questions and they won't talk to you if you don't have the prof of purchase. I have had it probably 15 years, so there is no way. When towing my travel trailer it seems to work fine. When I attach the 7 way plug the light comes on showing the C that it is hooked up on the unit under the dash, and the numbers come up when applying the brake showing the level of brake application. I also have a large work trailer that has always worked before, but I was hauling some material yesterday, and there was no response on the control when the plug was attached. I had never tested it before, but when I checked the pin in the plug it did not show any charge coming back to the plug on the truck 7 way when I had my wife pull the lever on. I went back and hooked it up to the travel trailer and it is still working fine on it. The wires look fine in the work trailer 7 way plug, and back to the brakes at the wheels. Shouldn't there be a charge at the truck pin in the 7 way plug when the brakes are applied? I'm just trying to figure out how this works and where to go to get this working again. Thanks.
Mike
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,166 PostsLatest Activity: Sep 30, 2025
