BillandCarole's avatar
Nov 02, 2014
110 Volt Electrical Doesn't Work
Were on the road and the 110 volt system for lights and wall plugs is dead. Things just quit in the middle of the afternoon. All the 110 appliances work (water heater, AC, Microwave, fridge etc) work. All the circuit breakers reset normally. I suspect the GFI has died. It won't test and I believe all the outlets and lights feed through it. Am I right? The circuit breaker for the rig (110) shuts off the micro etc when turned off so I believe its good. Suggestions please. Its now Saturday night and I have exhausted all other ideas including those that sparse book they call a manual suggest (not). Were running off the inverter and the 12 volt system. My voltage tester shows power going to the GFI.
Bill
