Jay_Pat's avatar
Jay_Pat
110 volt switch on hot water heater.
I turned on the 110v element of the hot water heater. The one mounted outside on the hot water heater.
It has the anode rod.
Yesterday, I tried to turn the switch off and it will not move. It is stuck in the on position.
I have pressed a lot harder than normal. It won't move from the on position.
Is this easy to replace?
Pop, the switch out?
Thoughts?
Pat
I used the breaker to turn the hot water heater off.
Having RV issues? Connect with others who have been in your shoes.24,234 PostsLatest Activity: Apr 11, 2025
