acramer's avatar
acramer
120 not working on some outlets
I have a 1995 Newmar Country Star with 22000 miles.. I am the original owner. My 120 plug for my refrig was not working so I used an extension code to plug it into my outlet outside near the frig. Everything worked ok. So I couldnt find why the plug inside the frig vent wasnt working. So I thought maybe the plug was bad. So I replaced the plug. The plug had 2 power lines connected to it. Now a lot of my 120 plugs wont work including the plug outside I used to initially make the frig work on 120. I have checked the circuit breaker both times when I only had the frig plug not working and then again when most plugs wernt working. Are then any other circuit breakers or fuses for the 120 circuit? Anybody know what might be wrong now? thanks...
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
