ehstars's avatar
ehstars
6 gallon hot water heater only delivers 4 gallons
Hello, I have a 6 year old Suburban SW6DE water heater which only gives me 4 gallons of hot water. This short change just started recently. The water gets heated to 135 degrees on either propane or electric, or both, but just doesn't deliver the whole 6 gallons. I have looked endlessly for leaks but no joy. The only thing that I see which might contribute slightly to this is my pressure relief valve is dripping a bit, about one drop every two seconds, more or less. But I doubt that would add up to two gallons in the 15 minutes it takes for the heating cycle to end, would it? Any advice would be great. Thanks.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
