Toyman1957
Oct 25, 2014Explorer
Allison trans. shift issue
Hello this is my first time here and post.
My 97 Newmar with 300 Cummins and Allison 6sp. just developed an issue tonight once I pulled into a campsite. It made a slight pop sound as I pulled in. I stopped and shifted into neutral. Then attempted to shift into reverse and got a flashing code on the shift indicator pad once I released the key pad reverse button. I tried to shift back to neutral and then into foreword without any luck. The key pad stated 6th gear so I tried to manually shift it down to first which the indicator said I was in but it did not shift into gear. I tried turning off the engine and restarting with out any luck.
Anybody got an idea what may be the problem?
Never had an issue with it before.
Fluid is full and not discolored.
