CincyRon's avatar
CincyRon
Battery Box for single Trojan T-1275
I picked up a single t-1275 plus for my fifth wheel but having a bit of trouble hunting down a battery box to replace the current one that's too small. The battery is listed as a group GC12 but googling GC12 battery box, or T-1275 battery box doesn't come up with anything. Looks like a 31 series box would work. Maybe a little tight at the top where the terminals are. Anyone here using a single 1275 that can steer me in the right direction? Would like to order from Amazon as I'm travelling right now and can get same or 2 day delivery where I'm staying.
Thanks!
  • I have a Trojan T-1275 plus with the fill caps in a row, not angled.
    The Moeller Injection-Molded Marine Battery Box (13.44" x 7.75" x 10.5") works out perfectly and even has enough room at the top.
    https://www.amazon.com/gp/product/B000MTB7X8
  • SoundGuy wrote:
    A NOCO HM426 would hold a T-1275 provided you have sufficient space to accommodate the box's external dimensions.
    theoldwizard1 wrote:
    There will be a lot of extra space inside to the battery to rattle around.
    Think outside the box :W - just sit the battery in a tray mounted in the box and it won't go anywhere. :R
  • theoldwizard1 wrote:
    I think you are reading the spec sheet wrong ! T1275 is 280 minutes @25A, so 2 would be 560 minutes. T105 is 447 minutes @25A. The other quick way is simply compare weights (seeing as the amount of lead in a flooded lead acid is the most important thing). 85# vs 62#
    The 280 figure is Reserve Capacity. The Amp Hour rating is 150 AH.
  • RoyB wrote:
    I love the Trojan 12V T-1275 Battery idea and its 150AH capacity... Alot of users on here for that battery. The charging voltages are slightly higher that the so called industry standard... I was thinking of using two of those those in my upcoming battery box build but looks like I am going to settle for the two groups of two Trojan 6V T105s in series. This will give me around 450Ahs of capacity...
  • Thanks for the all the info guys! For now I'm going with a single heavy duty storage container from Walmart. I've got some solar panels that I've owned for years that I need to install, purchase a charge controller, and then I'll probably buy another 1275 and re-visit the container issue.
  • A NOCO HM426 would hold a T-1275 provided you have sufficient space to accommodate the box's external dimensions.
  • RoyB's avatar
    RoyB
    Check with the TORKLIFT line of battery boxes. These have the slide off lid which is great when installed in tight places. They also have a model that has a small solar panel on it which may help help trickle charge your battery when in high Sun...
    You can find all sizes of plastic storage boxes at WALMART... I have used the ACTION PACKER Containers for a couple of batteries at one time...
    Another source is Truck Bed Tool Boxes from the auto parts places... They have a couple that are wedge shape to fit on top of the trailer tongue area... These come in all kinds of different dimensions... Order from AMAZON
    This is just me but I would not like the idea of just having one battery. I know exactly what would happen to me when camping off-grid haha... I gotta have a good plan B for just about everything when it comes to camping... Being a RV traveler I guess is not so demanding for Plan Bs... Just call the auto club as they say on TV...
    Roy Ken
  • The Noco HM327BKS (Group 27) is also a close fit (13.2 x 7.2 x 10.1) but still short. The NOCO Group 24-31 box is even shorter.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
