sign_man
Mar 02, 2017Explorer
battery charging
When charging (2) 12volt rv batteries through the on board converter/charger, would two honda eu2000's work any better than just using one genny to charge?
BFL13 wrote:
That raises an interesting point. I don't know the answer.
If the wiring is long and thin so R is high, is the 80 amper working just as hard but not getting so many amps through, as if it were on short, fat wires and doing all 80 amps?
BFL13 wrote:Almot wrote:
Not too misleading. Eu2000 is still 13A*120V output. 1600W(VA). So, unless they have 90A converter...
This says the 9280 wants 1300w input. We know it has a PF of 0.7, so the VA required = 1857 (it also wants a 20a circuit)
The Honda 2000 is rated at 1600VA continuous. Some folks say they can run their 9280s with a Honda 2000. I don't know how, but I know my Honda 3000 can do a bit better than rated.
Scroll down to the tables
http://www.bestconverter.com/9200-Series-Deck-Mount_c_84.html
Dang reset bug
NO: About the biggest converter made is 80 amps, Mine runs on a EU-2000i at full output (in fact it needs only 1,000 watts so power is left over.. Inverters I've seen 125 amp.. Still within a EU-2000i.
