grizzzman's avatar
grizzzman
Battery temp
I have moved from the world of MH to the world of TT. Anyways I have installed the Bogart TM2030 and SC2030 system. In the MH I ran 200 watts and heat caused by charging at 10+ amps was not much of a concern. I have so far installed 320 watts with another 320 watts in the garage waiting for install. The batteries in the MH were 12 volt and under the steps. They were well protected from thermo temp change. The TT batteries are CG2 6 volt on the tongue in black boxes. The battery temp sensor showed much more rapid temp swings due to the exposed "black" battery boxes. Now I can move the temp sensor from the post to the inner side to reduce the temp sensor issues, but I am now concerned the black boxes will cause higher temp changes that will cause higher water consumption and battery life issue's. What are your thought's on this subject? What would you do to control/reduce the rapid temp changes at the battery?
Thanks
  • landyacht318 wrote:
    I put a K type thermocouple on the side of my Northstar AGM battery on a center cell.
    Basically my battery is always in use, charging or discharging. I have been surprised at the average temperatures the battery holds, under discharge and how much it heats during absorption, then maintains the heat during discharge too.
    Like today at 2Pm. battery was taking 2.2 amps at 14.3v. ambient was 74.2, battery temp was 84.7f.
    Right now 11:30PM , 27Ah from full, battery temp 77.8f, ambient temp 69.7f.
    My charge controller does not have temp compensation.
    Ya it's kewl to see the relationships between temp/charge/discharge cycles isn't it?
  • MrWizard wrote:
    I think thick white highway line market paint is your best option for reducing box heat, unless you can find some insulated boxes
    Spray on foam, then painted over with white ?
    Yes white to reflect and not Adsorb heat is a good idea. Spray on foam thanks for the ideas.
  • I put a K type thermocouple on the side of my Northstar AGM battery on a center cell.
  • I think thick white highway line market paint is your best option for reducing box heat, unless you can find some insulated boxes
  • MrWizard wrote:
    paint them white ?
    the temp sensor should control the charge rate
    and thus control water loss
    you just end up with slower charging at reduced voltages
    Yep and I would like to avoid false slower charging if I can. Thank you for your thoughts.
  • paint them white ?
Having RV issues? Connect with others who have been in your shoes.24,345 PostsLatest Activity: Jan 03, 2026
