Lost_Traveller's avatar
Aug 20, 2016
Bottom slideout seal replacement
I have a 2002 Fleetwood Prowler 5th wheel. The bottom outside seal that is attached to the Rv body where the slideout slides in and out has come loose and breaking apart. I need to replace it. Any idea what that seal is called? Can I jack up the slideout enough without harm to be able to slide in the new seal? It looks like it is just glued to the aluminum trim piece and the slideout skides over it going in and out.
thanks for any help.
The Lost Travellers,
Bruce and Connie
  • I searched all over the net and couldn't find one about the bottom seal. But, thanks for the advice
    The lost travellers
    Bruce and Connie
Having RV issues? Connect with others who have been in your shoes.24,199 PostsLatest Activity: Feb 18, 2025
