werni9
Nov 24, 2014Explorer
breaker bad???
Atwood 10 gal elec/gas water heater. Electric not working, gas fine. The switch inside coach, to turn on electric, ??? It always gave me no trouble. I watched the voltage meter in the wall outlet and when I turn switch to on, it does not even twitch. Breaker isn't kicked. Should I put multi meter on breaker and check for juice there? Then check juice to switch? It is on a 2000 Winn. Ultimate Advantage. Just had the entire unit out because that is the way they built around it to replace a $4.00 check valve. The on/off switch for it is on the very back. If electric tests out ok, maybe the heating element? Thank you all.
