Ron_Nielson's avatar
Ron_Nielson
Burned Neutral Wires at the Buss in the Breaker Box
All of my neutral wires are burned at the buss at the breaker box about 2". Does this tell you anything about where a loose neutral connection is likely to be? I have read that the burnt wires need to be cut back to good copper and the buss replaced. Is that because the burned wires and buss has a higher resistance than clean connections?
The rest of the story: Trailer is a 2009 Arctic Fox 5th wheel. Only known electrical problem was probably 9 years ago plugging into a sloppy electrical pedestal at an Arkansas state park, and that burned the trailer's connector blade at the pedestal. Trailer is plugged into 120V power at the house all the time. We left KS and stopped overnight in Denver. Plugged into 120 and had power in the trailer for a few minutes, then no 120V power, so used 12V that night and went on to Ogden UT, plugged in no 120v power. Discovered that neither the 120V power nor generator power would come into the trailer, so figured that the transfer switch was bad. Changed out the transfer switch and then had 120V from both shore and generator. That's when I started smelling burning plastic smell in the breaker box. Can't say if they were burned before, but never a problem before this trip.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
