RckyMtnVia
Oct 08, 2022Explorer
Check Valve NPT & Shurflo Pump is NPS
Fresh water tank fills when I am on city water, so I was trying to install a Camco check valve, but the threading on the Shureflo is NPSm and the threading on the Camco is MPT & FPT. The brass check valve chewed up the plastic threading on the Shureflo. I even bought a Valterra check valve but it is the same. Any thoughts on what I can do? One solution is to buy a sharkbite check valve and cut the line to install it. Thanks.
Update! So in my research I found out you cannot use Sharkbite on braided nylon hose, so that is not a solution.
