RJsfishin
Mar 21, 2014Explorer
I had about the same as you describe, only mine just wouldn't run at all sometimes. It was definently a bad connection somewhere.I got real tired of looking for it. Then someone here told me that my system activates the ground on the solenoid, not the hot side. So I installed a push button switch on the dash that's labeled "manual override". All it does is ground the solenoid on the pump motor. I have had to use it many times, and it has never failed to operate.
