211Racing
Mar 13, 2022Explorer
Expert Fuel Pump Opinions Needed!
Just got a 2002 Tioga 24D. Base is a Ford e350 Super Duty van. Will turn over strong, but starts for only an instant. With the help of Starting Fluid, will run for several instants. Zero pressure at the fuel rail. Tightened the gas cap. Replaced the Fuel Pump Relay. Replaced the Fuel Pump Fuse. Replaced the Fuel Pump Filter. Checked and cleaned the Inertia Switch (button is down). Thumped the bottom of the tank several dozen times. Absolutely zero effect. I am reluctantly moving ahead to draining the 40+ gallons of fuel and dropping the fuel tank to replace the Fuel Pump. Can you think of anything that I have missed before I commit to this job? Thank you for your help. (And ... I checked to see if I could access the Fuel Pump through the floor in the back of the RV. Lovely thought, but not possible).
