tvfrfireman's avatar
tvfrfireman
Having trouble repairing shwintec slide
I purchased from the Lippert factory the new side rails and repair kit for our four year old slide. The directions were clear and I had no problems replacing the parts. I did find some installation issues from the DRV factory. One was a flexible thick plastic piece that was laid in the slide opening before the slide installation to insure water did not get inside the trailer. I was wadded up and had been interfering with the slide from the time it was new. Anyway, I got it all together and tried to operate the slide and it moves one inch and stops. The red light in the control box blinks 8 flashes which indicates and short in the wire between the controller and the slide motor. I checked all five wires in the cluster for continuity and it seems to be find. Anyone else had this problem? Thanks for any sage advice or tips.
Having RV issues? Connect with others who have been in your shoes.24,228 PostsLatest Activity: Apr 03, 2025
