gandk1011
May 24, 2020Explorer
House/Chassis Battery Charging Issue
I'm new here to post, but always appreciate the help I receive from others questions. I edited some errors initially posted.
I installed a Trick L Charge to keep the Chassis (edited) battery charged when in storage. Well it quit working. The relay near the chassis battery that I connected the trick l start to shows 2 volts on both sides. So I don't think the problem is the Trick L Start.
The large positive wire from the relay near the chassis battery leads to the house battery compartment. The RV house battery compartment component it is attached to has two large gauge wires and a small yellow and black wire. The top wire on this component (which runs to the relay by the coach battery) shows 2 volts the bottom wire (which goes to the house battery) shows 13-14 volts.
**It appears to me this RV component isn't transferring power towards the chassis battery relay.
I'm not sure what the yellow and black wire on this RV component does? Not sure what this part or it's function but could that be the cause of the Trick L a Charge failure to maintain the house battery? Any other troubleshooting I can do? Thanks in advance.
Greg
2017 Coachman Leprechaun Class C E450 Ford Chassis
Greg
