mdecorso's avatar
mdecorso
Low voltage at atwood rv heater, help please
I am getting a low voltage reading at my heater. I am testing it with my voltmeter at the blower motor. I get a 10.6 reading when plugged into shore power. Furthur testing at the rv power distribution panel/fuse panel gives me a similar reading when I test from the blue shore power line attached to the 12v panel to the white ground input coming from my house battery. My house battery is at 12v, a little low I know, but a separate issue. My question is does this mean that my white ground has a bad connection somewhere?
The problem becomes evident when it gets dark and I turn on a couple of lights. They pull enough power away from the heater to slow the blowere and thus drop the sail switch, so no heat. At bedtime, lights go off, heater on, warm time.
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
