MEXICOWANDERER's avatar
Sep 28, 2013
Major Battery Charging Configuration Via Vehicle Alternator
  • Forget about what you learned or believe
  • Disconnect charging lead wires from vehicle alternator. This means all of them
  • Run a huge wire from alternator to an ACCESSIBLE Circuit Breaker rated 200% of rated alternator output amperes
  • From this breaker continue to HOUSE batteries, same gauge wire
  • With a 130 ampere alternator I would use FOUR GAUGE WIRE, the entire distance
  • With a 270 ampere alternator TWO AUGHT wire the entire distance
  • Run an equivalent gauge wire from the engine block to house battery negative
  • At house battery positive use minimum 100 amp rated separator I would choose 200 amp and run the charge lead wire to the disconnected original alternator output wires.
