bedpan's avatar
bedpan
New TT, New Fridge - Is the venting ok?
Just bought a Starcraft 18BH. It comes with a Norcold N306R. It is vented out the side of the trailer.
Wife noticed the Countertop above the fridge gets quite warm so I opened up the vent to have a look. There is a 45 degree baffle setup to direct heat out the vent. That said the baffle is loose fitted, with gaps around it.
http://googledrive.com/host/0BwxcD2SubWa4OEphVWYzRzRTazQ/1.jpg
Any thoughts if I were to use some silver reflective tape to seal things up? This is my first TT so I am not sure how it should look in here. I would think in my little reading that the more heat I can get out the better the fridge will work. That said the fridge is working well so far without any issues.
Also any benefit to adding a fan in here to push the hot air out? Maybe I am just over thinking things. If the fridge is working fine, maybe I should just leave well enough alone...
Thoughts?
Many thanks in advance!
Mike
