Ro646a's avatar
Ro646a
No AC power from shore cord
I have had our motorhome plugged into shore
power in my driveway, as always, but this morning I went out there and my house batteries were dead and there is no 110 volt power to any of the outlets.
I started the generator and the batteries are charging and all the 12 volt systems are working, as well as the 110 volt heat pump, but there is no power to any if the 110 volt outlets.
I have it plugged into a standard 220 volt 50 amp, grounded outlet, and I have confirmed that I have power going into the shore power cord. I have had it plugged into the same outlet that I always use at home.
Any thoughts as what I should check next?
Thanks
āš Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★"?
    Forum Posting Help and Support is reserved for questions related to posting issues with Open Roads Forum sites, member profile and photo testing, and for reporting account issues. Please avoid using this forum for RV related questions, as doing so can delay responses to your thread. Instead, select the Sub-Forum which corresponds to the subject of your topic. Thank-you!
Moved from FORUM POSTING HELP AND SUPPORT
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 21, 2025
