- Clay_LExplorer
joebedford wrote:
I ordered the parts online to do a tune up on my generator. The description of the fuel filter says that if you have one near the carb to replace it with a fitting. I'm pretty certain that the questionable item by my carb is already a fitting not a filter.
Thanks for the help.
Yes it is. The filter on the fuel pump is the newer filter that replaced the older one that had a smaller diameter and was longer. The fitting in the second picture is the adapter that replaced the old second filter when they started using just the one filter on the pump. - joebedfordNomad III ordered the parts online to do a tune up on my generator. The description of the fuel filter says that if you have one near the carb to replace it with a fitting. I'm pretty certain that the questionable item by my carb is already a fitting not a filter.
Thanks for the help. - joebedfordNomad II
is it friday yet? wrote:
This is your style of filter I believe. In the first photo, you can see the clamp for the barb on the left and the fitting on the right.
http://onanparts.com/index.php?main_page=product_info&products_id=539
Here's the link:
Clicky
I agree - that's the filter before the fuel pump. - joebedfordNomad II
OldF**t wrote:
I'm trying to understand if the second photo is showing a filter or a fitting???
If you still have the carb filter it would probably be a good idea to replace it with the adapter. - OldF__tExplorerThey are both filters. Originally Onan supplied two filters on the gennys. The one underneath the carb caused problems with leaks and at some time Onan decided to replace the problem filters with straight adapters. If you still have the carb filter it would probably be a good idea to replace it with the adapter.
- is_it_friday_yeExplorerThis is your style of filter I believe. In the first photo, you can see the clamp for the barb on the left and the fitting on the right.
http://onanparts.com/index.php?main_page=product_info&products_id=539 - TEXASExplorerYour right joe. Brain stuck on fitting.
Thanks for catching it. - joebedfordNomad II
TEXAS wrote:
Pretty sure the first picture is a filter not a fitting.
The first picture is a fuel fitting. The second is just a fitting. - TEXASExplorerThe first picture is a fuel fitting. The second is just a fitting.
- joebedfordNomad IICheck the photos in the OP - I added circles to indicate the filter and potential filter.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 23, 2025
