JimInMich's avatar
JimInMich
PD9260c 13.48 volt charge instead of 13.6?
Just got my new PD9260c converter installed. Checked my battery voltage before plugging in, 12.67 volts at batteries. Plugged in the 9260 and got a reading of 13.48 volts at batteries. Manual states it should be 13.6 volts while charging.
One thing I noticed, my power cables are aluminum ( where I was attaching to the converter ). I know back in the day they used aluminum wire to save cost's. I'm wondering if, due to wire size, distance and/or it being aluminum, is getting me the lower charge rate? Do you think the .12 volts will make that much of a difference?
I can not upgrade the wiring, so no need to tell me to do that. :)
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
