RKW's avatar
RKW
Aug 13, 2014
Prodigy Brake controller display question
Are the amp values supposed to show on the display when you are routinely braking (after you set it manually) OR are they displayed on only during the manual setting?
Thanks in advance
  • ktmrfs's avatar
    ktmrfs
    normal display on prodigy is VOLTS, not amps. shows under manual operation and normal braking.
  • Only the prodigy P3 will show amps.
    You have to select the output from the trouble shooting screen.
  • Mine show as I am braking. The harder I press on the brake pedal, the more amps I see on the readout.
Having RV issues? Connect with others who have been in your shoes.24,402 PostsLatest Activity: Jul 30, 2026
