seaninator's avatar
seaninator
Refridgerator Problems
Please help. I had my Dometic refridgerator working at my house on AC but when I left and switched it to gas it stoppped working and the check light came on. When I got home I plugged back into AC but no luck. I can hear a clicking on the back and then the check light comes on again.
  • I know this is a old post but it sure helped me. I turned the how water on let it run a couple minutes turned the fridge on gas and wow it stayed running thanks so much.
  • Check your gfi outlet to see if it tripped. Make sure the outlet has power.
  • First, the obvious questions.. Gas is turned on? You have gas in the cylinders? Auto switch over lever to full cylinder? Purged the gas lines before trying to start fridge on gas?
    I know that if mine sets for a couple of weeks, with the gas off, when I turn it on, it takes a minute or so for me to get the stove top burners to light! I turn on the hood fan, turn on the center knob and hold the clicker until it lights. Then I turn on the others and let them run for a minute or two.
    Then I light my HW tank. It might take a couple of tries to get it to fire (end of the gas line).
    The fridge is in the center of all of this. After the HW lights, the fridge will usually light on the first try.
    If all of the above checks out, see if you have a plugged up flow tube for the flame to get air from.
    Good luck!
    Mitch
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
